BT.com
Wishlist
Kingston 1GB DDR2-800 CL6 DIMM Memory Module
Kingston 1GB DDR2-800 CL6 DIMM...
£14.28
£14.28
Add to wishlist
Delivery
Standard Due date unavailable
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR2 - 1 GB - DIMM 240-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
Limited lifetime warranty (Germany, Austria and France - 10 years)
Gateway FX540X, FX540XT, FX540XV; MAXDATA Favorit 4000 I, 4000 IS, 4000 IT BTX
1 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Module Configuration
128 x 64
Compatible Slots
1 x memory - DIMM 240-pin
Gateway FX540X, FX540XT, FX540XV , MAXDATA Favorit 4000 I, 4000 IS, 4000 IT BTX
Scroll to top
