BT.com
Wishlist
Kingston 1GB 667MHz Module
£15.02
£15.02
Add to wishlist
Delivery
Standard Due date unavailable
Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
IBM ThinkCentre A52 8153, 8154, 8166, 8167;
IBM ThinkCentre A52 8155, 8156, 1857;
IBM ThinkCentre A52 8158, 8159, 8160;
IBM ThinkCentre A52 8161, 8162, 8163;
IBM ThinkCentre A52 8164, 8165;
IBM ThinkCentre A52 8168, 8169, 8170;
IBM ThinkCentre M52 8099, 8116, 8215;
IBM ThinkCentre M52 8110, 8111, 8112;
IBM ThinkCentre M52 8113, 8114, 8115;
IBM ThinkCentre M52 8211, 8212, 8213, 8214, 8215;
IBM ThinkCentre M52 9210, 9211.
Kingston - DDR2 - 1 GB - DIMM 240-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Unbuffered
IBM 30R5126, IBM 73P4984, IBM 40J8870, IBM 41X4256
Limited lifetime warranty (Germany, Austria and France - 10 years)
IBM SurePOS 700; Lenovo H210; IdeaCentre K200; K210; J100; J110; J115; J200; J200p; J205; K100; Q100; S200; S205; ThinkCentre A52; A53; A55; A57; A58; A60; A61; A62; M52; M55; M55e; M55p; M57; M57e; M57p; M58e; M58p
1 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
IBM SurePOS 700 4800-743, 4800-783 , Lenovo H210 5355 , Lenovo IdeaCentre K200 , Lenovo IdeaCentre K210 5313 , Lenovo J100 , Lenovo J110 , Lenovo J115 , Lenovo J200 , Lenovo J200p 9689 , Lenovo J205 , Lenovo K100 , Lenovo Q100 , Lenovo S200 , Lenovo S205 9680 , Lenovo ThinkCentre A52 , Lenovo ThinkCentre A53 , Lenovo ThinkCentre A55 , Lenovo ThinkCentre A57 , Lenovo ThinkCentre A58 7522, 7611, 7705 , Lenovo ThinkCentre A60 , Lenovo ThinkCentre A61 , Lenovo ThinkCentre A62 7057, 7061, 7062, 9485, 9486, 9623, 9624, 9625, 9705, 9935, 9953 , Lenovo ThinkCentre M52 , Lenovo ThinkCentre M55 , Lenovo ThinkCentre M55e , Lenovo ThinkCentre M55p , Lenovo ThinkCentre M57 6008, 6010, 6019, 6062, 6065, 6066, 6067, 6068, 6069, 6071, 6072, 6073, 6074, 6075, 6076, 6077, 6079, 6081, 6082, 6086, 6087, 6089, 9172, 9174, 9181, 9970, 9978 , Lenovo ThinkCentre M57e , Lenovo ThinkCentre M57p 6064, 6067, 6073, 6078, 9011, 9012, 9013, 9014, 9018, 9019, 9071, 9087, 9088, 9089, 9096, 9160, 9162, 9163, 9164, 9193, 9194, 9196, 9967, 9979 , Lenovo ThinkCentre M58e 7259, 7268, 7269, 7270, 7279, 7298, 7303, 7307, 7408, 7491, 7506, 7508, 7514 , Lenovo ThinkCentre M58p 9964
£15.02
Save on this ideal PC Build kit!
Save £8.29
£34.19
Scroll to top
