BT.com
Wishlist
Kingston 16GB Kit
Kingston 16GB Kit
Delivery
Standard Due date unavailable
All Kingston memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for.
Kingston - DDR2 - 16 GB: 2 x 8 GB - FB-DIMM 240-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Fully Buffered
Voltage
1.8 V
Sun SESX2D1Z, Sun X4290AF
Limited lifetime warranty (Germany, Austria and France - 10 years)
Sun Blade T6320 Server Module; SPARC Enterprise T5120, T5140, T5220, T5240, T5440
16 GB: 2 x 8 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
FB-DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Fully Buffered
Voltage
1.8 V
Compatible Slots
2 x memory - FB-DIMM 240-pin
Sun Blade T6320 Server Module , Sun SPARC Enterprise T5120, T5140, T5220, T5240, T5440
Scroll to top
