BT.com
Wishlist
Kingston 16GB Kit
Kingston 16GB Kit
£315.04
Kingston 16GB Kit
Kingston 16GB Kit
£315.04
Add to wishlist
Delivery
Standard Due date unavailable
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston - DDR2 - 16 GB: 2 x 8 GB - FB-DIMM 240-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR2 SDRAM - FB-DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC Chipkill
Speed
667 MHz (PC2-5300)
Fully Buffered
IBM 40V2751
Limited lifetime warranty (Germany, Austria and France - 10 years)
Lenovo System x3650
16 GB: 2 x 8 GB
Upgrade Type
System specific
IBM 40V2751
DRAM
DDR2 SDRAM
FB-DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC Chipkill
Fully Buffered
Compatible Slots
2 x memory - FB-DIMM 240-pin
Lenovo System x3650
Kingston 16GB Kit
Kingston 16GB Kit
£315.04
Save on this ideal PC Build kit!
Save £16.94
£340.42
Scroll to top
