BT.com
Wishlist
Kingston 16GB DT MICRODUO USB 2.0
£7.90
More than 50 in stock
£7.90
Add to wishlist
Delivery
Standard 3-5 working days
Expanded storage for tablets and smartphones.
Kingston's DataTraveler® microDuo provides additional storage in a small,convenient form factor for tablets and smartphones that support the USB OTG (On-The-Go) functionality. The USB OTG standard allows mobile devices to connect directly to supported USB devices. DataTraveler microDuo allows microUSB ports, often used for charging devices, to be used as expansion ports for up to 32GB of additional memory. Ideal for storing large files while traveling, DTDUO gives plug-and-play functionality to tablets and smartphones without microSD ports at a lower price per GB than the extra built-in storage on a mobile device.
With smartphones and tablets recording HD video and taking higher resolution photos, space on these devices gets used up faster than ever. DTDUO lets users move files, photos, videos and more -- without plugging into a PC1 -- to offload or backup content. Sharing large files between mobile devices is easier than using online cloud services, and there's no need for a cable to transfer data between the device and a PC.
DT microDuo is small, lightweight and easy to take anywhere, plus its sleek design complements any mobile device. Its rotating cap protects the micro USB connector from damage.
DataTraveler microDuo is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
FEATURES / BENEFITS
>> USB OTG (On-The-Go) -- a standard which enables host functionality in certain phones/tablets with microUSB ports,enabling connectivity to USB devices like Kingston's DT microDuo
>> 2-in-1 -- microUSB and USB 2.0 connectors for easy transfer of files between smartphones, tablets and computers
>> Plug-and-Play -- simply connect as you would a standard USB Flash drive
>> Convenient -- ultra-small, pocket-sized design for ease of transport
  • Supports USB OTG (On-The-Go) functionality
  • Expanded storage for tablets and smartphones
  • For Android™ 4.0+ devices with USB OTG support
  • Easily transfer and back up files, photos and videos to free up space
  • Great for storing large files, including movies and music libraries, while travelling.
Kingston DataTraveler microDuo - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Microsoft Windows 7, Microsoft Windows Vista, Linux 2.6 or later, Apple MacOS X 10.6.x or later, Windows 8, Microsoft Windows RT, Android 4.0 or later, Windows 8.1
5 years warranty
USB flash drive
Storage Capacity
16 GB
Compatibility
Non-specific
Interface Type
USB 2.0
USB On-The-Go compatible, swivel cap, micro-USB connector
Plug and Play
Limited warranty - 5 years
27.63 mm
16.46 mm
8.56 mm
60 °C
Scroll to top
