BT.com
Wishlist
Kingston 16GB DDR4-2400MHz Reg ECC Module
Delivery
Standard 1-3 working days
Kingston manufacture the most reliable memory you can buy for a HP Server. Kingstons legendary reputation is built around reliable memory, that will power your HP server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this HP compatible memory module.
Each chip that is built onto the HP memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of HP server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all HP memory upgrades for Server environments.
Kingston - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
Lead Plating
Gold
HP 846740-001
Limited lifetime warranty (Russia - 10 years)
HPE Apollo 4520 Gen9; ProLiant DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL580 Gen9, DL60 Gen9, DL80 Gen9, for Microsoft Azure Stack, ML110 Gen9, ML150 Gen9, WS460c Gen9, XL190r Gen9; SimpliVity 380 Gen9; StoreEasy 3850; Synergy 480 Gen9, 620 Gen9, 660 Gen9, 680 Gen9
16 GB
Upgrade Type
System specific
HP 846740-001
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
HPE Apollo 4520 Gen9 , HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL360 Gen9 Special Server, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL388 Gen9, DL388 Gen9 Base, DL580 Gen9, DL580 Gen9 Database, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, for Microsoft Azure Stack, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL190r Gen9 , HPE SimpliVity 380 Gen9 Node , HPE StoreEasy 3850 Gateway Single Node , HPE Synergy 480 Gen9 Compute Module, 620 Gen9 2S-EX Base Compute Module, 620 Gen9 2S-EX Performance Compute Module, 660 Gen9 Base Compute Module, 660 Gen9 Compute Module, 660 Gen9 Entry Compute Module, 660 Gen9 Expanded Storage Compute Module, 660 Gen9 Performance Compute Module, 680 Gen9 4S-EX Base Compute Module, 680 Gen9 4S-EX Performance Compute Module
Scroll to top
