BT.com
Wishlist
Kingston 16GB DDR4-2133MHz Reg ECC Module
Kingston 16GB DDR4-2133MHz Reg ECC...
£171.28
33 in stock
£171.28
Add to wishlist
Delivery
Standard 1-3 working days
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge R730, T630; Precision Tower 5810, 7810
16 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge R730, T630 , Dell Precision Tower 5810, 7810
£171.28
Save on this ideal PC Build kit!
Save £8.43
£190.50
Scroll to top
