BT.com
Wishlist
Kingston 16GB DDR3-1600MHZ ECC Module
Delivery
Standard 3-5 working days
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products for HP servers, at an attractive price. Selecting the right memory for a server is as important as using the right memory manufacturer. Kingston system-specific HP server memory is designed to be ultra-reliable and reduce the total cost of ownership. Each Kingston memory module is designed, manufactured, tested and tailored to maximize the performance of a HP server system, and guaranteed to be compatible in that system. Kingston's system-specific server memory is ideal for customers who use HP servers and know the name and model number of their system.
Kingston - DDR3 - 16 GB - DIMM 240-pin - registered
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Registered
HP 684066-B21, HP 672631-B21
Limited lifetime warranty (Russia - 10 years)
HPE ProLiant BL420c Gen8, BL460c Gen8, BL465c G7, BL660c Gen8, BL685c G7, DL160 Gen8, DL165 G7, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385 G7, DL585 G7, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, WS460c Gen8
16 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Registered
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL420c Gen8, BL460c Gen8, BL465c G7, BL660c Gen8, BL685c G7, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL585 G7, DL585 G7 Base, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, WS460c Gen8
Scroll to top
