BT.com
Wishlist
Kingston 16GB 2133MHz DDR3 CL11 DIMM (Kit of 2) XMP HyperX Predator
Kingston 16GB 2133MHz DDR3 CL11...
£134.43
15 in stock
£134.43
Add to wishlist
Delivery
Standard 1-3 working days
HyperX® Predator memory has the fastest speeds, lowest latencies and highest capacities available in HyperX memory. It’s designed for and compatible with all popular brands of motherboards. HyperX Predator is ultra-reliable and 100 per cent factory tested to ensure that it will deliver higher performance, ultraresponsive multitasking and a faster system.Predator features a tall heat spreader for greater heat dissipation, and its black PCB complements the look and design of the latest PC hardware. Intel XMP-certified kits are available up to 2800MHz. Users can overclock their platforms simply by selecting a profile, with no need for manual adjustments in BIOS.For added peace of mind, HyperX Predator is backed by a lifetime warranty, free technical support and legendary reliability.
Kingston HyperX Predator - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC3-17000 )
Latency Timings
CL11 ( 11-12-12 )
Heat sink, dual rank, eight banks, Serial Presence Detect (SPD), Intel Extreme Memory Profiles (XMP) , unbuffered
Voltage
1.6 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.614
Speed
Latency Timings
CL11 ( 11-12-12 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.6 V
Lead Plating
Gold
RAM Performance
SPD - 1600 MHz - 1.5 V - CL11 - 11-11-11 , Intel Extreme Memory Profiles (XMP) - 1600 MHz - 1.5 V - CL9 - 9-9-9 , Intel Extreme Memory Profiles (XMP) - 2133 MHz - 1.6 V - CL11 - 11-12-12
Colour Category
Kingston 16GB 2133MHz DDR3 CL11 DIMM (Kit of 2) XMP...
£134.43
Save on this ideal PC Build kit!
Save £9.16
£153.99
Scroll to top
