BT.com
Wishlist
Kingston 16GB 1600MHz DDR3L ECC Reg CL11 DIMM DR x4 1.35V w/TS
Kingston 16GB 1600MHz DDR3L ECC Reg...
£132.88
£132.88
Add to wishlist
Delivery
Standard Due date unavailable
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Temperature monitoring, dual rank, registered
Voltage
1.35 V
Lead Plating
Gold
16 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
2048 x 72
Chips Organization
X4
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Kingston 16GB 1600MHz DDR3L ECC Reg CL11 DIMM DR x4...
£132.88
Save on this ideal PC Build kit!
Save £8.29
£152.05
Scroll to top
