BT.com
Wishlist
Kingston 16GB (4 x 4GB) HyperX Predator 1866MHz DDR3 240-pin DIMM CL10 XMP
Kingston 16GB (4 x 4GB) HyperX...
£98.35
15 in stock
£98.35
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
Kingston HyperX Predator - DDR3 - 16 GB : 4 x 4 GB - DIMM 240-pin
RAM memory
16 GB : 4 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-14900 )
Latency Timings
CL10 ( 10-11-10 )
Heat sink, single rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, quad channel , unbuffered
Voltage
1.5 V
Lead Plating
Gold
16 GB : 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
2.12
Speed
Latency Timings
CL10 ( 10-11-10 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
4 x memory - DIMM 240-pin
Kingston 16GB (4 x 4GB) HyperX Predator 1866MHz DDR3...
£98.35
Save on this ideal PC Build kit!
Save £9.28
£117.94
Scroll to top
