BT.com
Wishlist
Kingston 16GB (1x16GB) DDR3 1866MHz ECC CL13
Delivery
Standard Due date unavailable
Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL13
Registered
Voltage
1.5 V
Lead Plating
Gold
Apple Mac Pro
16 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL13
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Apple Mac Pro
Scroll to top
