BT.com
Wishlist
Kingston 128GB SSDNow V100 SATA-300 2.5" Solid State Drive Desktop Bundle
Delivery
Standard Due date unavailable
Kingston Technology's SSDNow V100 solid-state drives are ideal for consumers or small businesses. These drives are an affordable way to extend the life of desktops or notebooks whilst dramatically increasing their performance and multitasking capabilities!
Kingston Technology's SSDNow V100 solid-state drive dramatically improves performance with impressive speeds. It makes any user more productive by speeding up boot times and application loads while removing hard drive crashes and failures.
SSDNow V100 is ideal for consumers or small businesses looking for an affordable way to extend the life of desktops or notebooks at a lower cost than a replacement system. It's perfect for home users, freelance designers and photographers, video editors, researchers, administrators and educators, and anyone who travels for their job. It's built with no moving parts to provide durability and reliability and to meet the needs of professionals in the office or on the road.
The switch to an SSD solution is made easy via upgrade kits for either notebook or desktop systems. The V100 kits include everything for installing the SSD.
Kingston SSDNow V100 Desktop Bundle - solid state drive - 128 GB - SATA 3Gb/s
Solid state drive - internal
128 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H (in 3.5" carrier)
SATA 3Gb/s
Data Transfer Rate
300 MBps
Shock resistant, Silent HDD, TRIM support , S.M.A.R.T.
7 cm x 10 cm x 1 cm
77 g
3 years warranty
128 GB
2.5" x 1/8H
SATA 3Gb/s
7 cm
10 cm
1 cm
77 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
250 MBps (read) / 230 MBps (write)
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H or 3.5" (with included bay adapter)
Software Included
Drivers & Utilities
3.5-inch bay adapter
1 x Serial ATA cable - internal , 1 x Serial ATA power adapter - internal
Mounting Kit
Included
Limited warranty - 3 years , Technical support
70 °C
Scroll to top
