BT.com
Wishlist
Kingston 120GB SSDNow V300 SATA 6Gb/s 2.5" 7mm Solid State Drive
The cost effective way to upgrade your PC!
Select:
1 on order, no confirmed delivery date
Delivery
Standard Due date unavailable
Revive your computer
Get more life out of your computer and maximise your existing investment by replacing your old hard drive with a Kingston® SSDNow V300 solid-state drive. It's the most cost-efficient way to dramatically improve the responsiveness of your system -- and it's less disruptive than migrating your data to a new system.
SSDNow V300 features an LSI® SandForce® controller customised for Kingston and optimised for next-generation Flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it's made with solid-state components and has no moving parts, it's shock-proof and withstands drops and bumps.
It's backed by a three-year warranty, free technical support and legendary Kingston reliability.
  • Cost-effective system upgrade
  • Makes your system more responsive
  • Maximises your computer investment
  • Faster -- improves speed of loading applications and system boot up
  • Reliable -- with no moving parts, solid-state drives are less likely to fail than standard hard drives
  • Economical -- design optimised to make migrating to an SSD more affordable
  • Form factor -- 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
  • Silent -- cool and silent operation
  • Guaranteed -- three-year warranty, free technical support
  • Form factor 2.5
  • Interface SATA Rev. 3.0 (6Gb/s) - with backwards compatibility to SATA Rev. 2.0
  • Capacity 120GB
  • Sequential reads2 S ATA Rev. 3.0 up to: 450MB/s
  • Sequential writes2 S ATA Rev. 3.0 up to: 450MB/s
  • Maximum random 4k read/write
  • 120GB -- up to 85,000 / up to 55,000 IOPS
  • PCMARK® Vantage HDD Suite score 120GB: 49,000
  • Power consumption 0.640 W idle / 1.423 W read / 2.052 W write
  • Storage temperatures -40°C~85°C
  • Operating temperatures 0°C~70°C
  • Dimensions 69.8mm x 100.1mm x 7mm
  • Weight 86g
  • Vibration operating 2.17G peak (7-800Hz)
  • Vibration non-operating 20G peak (10-2000Hz)
  • Life expectancy 1 million hours MTBF
  • Warranty/support three-year warranty with free technical support
  • Total Bytes Written (TBW) 120GB:64TB
See It In Action
Kingston SSDNow V300 - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, SandForce Driven
69.8 mm x 100.1 mm x 7 mm
86 g
Microsoft Certification
Compatible with Windows 7
3 years warranty
120 GB
2.5"
SATA 6Gb/s
69.8 mm
100.1 mm
7 mm
86 g
Performance
SSD Endurance
64 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
450 MBps (read) / 450 MBps (write)
Maximum 4KB Random Write
55000 IOPS
Maximum 4KB Random Read
85000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.423 Watt (read) , 2.052 Watt (write) , 0.64 Watt (idle)
ISO 9001:2008, SGS
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Accessories
£7.98
£14.23
£19.74
£18.51
Resources
The following resources are available for the Kingston 120GB SSDNow V300 SATA 6Gb/s 2.5" 7mm Solid State Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* An very underwhelming day but perseverance wins in the end.
Reviewed by spex on 19/04/2014
Saturday morning and i've fallen back to sleep after being woken up at 6am by my neighbours parrot when i hear the post drop something through the letter box. Deep joy its my drive. Breakfast and a cup of tea in hand and i sat down to install it. That was 8:10am, i have it up and running at last at 23:43. Win7 install kept crashing, i tried to install it on a normall HD and it crashed again, always at the spinning/ pulsing windows icon. I installed vista 64 on the ssd no problem. Finally at 22:30 i pressed shift and F10 at the moment it said you can't run safe mode during setup and uninstalled my gpu and an unknown device in device manager, which finally let the install complete. On sorting my screen resolution i noticed my tv was plugged in, if only i hadn't been half asleep and noticed it earlier. Win7 installed quicker on the ssd noticibly now to give it a test or two.
Scroll to top
