BT.com
Wishlist
KeySonic Mini USB Keyboard
£22.26
£22.26
Add to wishlist
Delivery
Standard Due date unavailable
ACK-3400 U is an ultra-compact mini-keyboard with unique "SoftSkin" coating; only 218×103×15 mm (8]"×]"×4") large! Full functionality of a standard-layout keyboard. Particularly quiet operation and tactile feedback due to high quality "X-Type" membrane technology. Appealing blue status LEDs for Caps Lock, Num Lock, and Scroll Lock. Plug & Play installation.
KeySonic ACK-3400 U - keyboard
Keyboard - wired
USB
21.8 cm x 10.3 cm x 1.5 cm
250 g
Keyboard - wired
USB
Input Device
21.8 cm
10.3 cm
1.5 cm
250 g
1 x USB
1 x USB cable - 1.5 m
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Keyboard 1
Reviewed by Anonymous on 10/03/2014
Design review
3* Takes some getting used to.
Reviewed by Anonymous on 03/07/2015
At first I thought it was broken but it turns out you just need to hammer on the keys; they're not very sensitive at all.
If it weren't for the fact that it's such a great form factor for my needs I would probably not want to use it, basically because the resistance in the buttons feel like a design-flaw (you almost need to use the same force as with a mechanical typewriter (but thankfully the throw on the keys is a lot lot shorter than a mechanical keyboard).
Due to it having the form factor I need I'm persevering with it & although it does take some getting used to (not just because you really do need to hammer the keys, but because the keys really are quite small and very close together (and there's only one shift key)) as I am getting used to it, it is getting easier to use.
If I had to type on this keyboard very extensively and not just now and again I'm not sure how I'd feel about using it. I think I could probably get used to it but the keys feel needlessly stiff.
Scroll to top
