BT.com
Wishlist
Kensington Wall Laptop Power Adapter
Kensington Wall Laptop Power...
£87.57
£87.57
Add to wishlist
Delivery
Standard Due date unavailable
The Kensington Wall Laptop Power Adapter is ideal whether you're looking for a replacement or a secondary power adapter at home or on the move. It provides the reliability that you need and is compatible with a wide range of laptops from leading manufacturers.
Kensington Wall Laptop Power Adapter - power adapter - 90 Watt
Power adapter - external
320 g
Europe
Power Capacity
90 Watt
5.2 cm x 13.1 cm x 2.8 cm
Environmental Standards
ENERGY STAR
2 years warranty
Europe
Power Capacity
90 Watt
Power cable
Overheat protection, over current protection, over voltage protection, short-circuit protection
ENERGY STAR
5.2 cm
13.1 cm
2.8 cm
320 g
Scroll to top
