BT.com
Wishlist
Kensington UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub - Black
Kensington UA3000E USB 3.0 Ethernet...
£48.12
8 in stock
£48.12
Add to wishlist
Delivery
Standard 3-5 working days
Many newer laptops do not come with an Ethernet port, leaving users only WiFi to get connected to the Internet. The UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub provides a wired connectivity option with lightning fast transfer speeds where wireless access isnt available or if you have a broken internal network card. The USB 3.0 Ethernet adapter simply plugs into an available port on your laptop and supports 10/100/1000 BASE-T performance. Also included are three USB 3.0 ports for additional device expansion. The adapter is compatible with systems running Windows 8.1/8/7/Vista/XP, as well as Mac OS X 10.6 and later.
Kensington UA3000E - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1 + USB 3.0 x 3
10.5 cm x 4.5 cm x 2.4 cm
68 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
1 x 1000Base-T - RJ-45 , 3 x USB 3.0 - 9 pin USB Type A
Plug and Play
10.5 cm
4.5 cm
2.4 cm
68 g
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
