Click to visit BT.com
BT.com
Wishlist
Kensington Slim MicroSaver Security Kit
Quicklinx: 2J7JWS00
Mfr#: 64020
Type: Security Kit
Stock Status: Used Stock
Express delivery Order within the next 22 hours for delivery on Friday
£30.46
The MicroSaver lock head features the patented T-bar locking mechanism. The T-bar provides a tight fit with the Kensington Security Slot. A rubber bumper ensures a snug fit between the lock and the security slot and protects your hardware. A further deterrent is the tamper evident feature. When a Kensington MicroSaver lock is tampered with, it locks itself down and can even trap foreign keys.
All Kensington locks are built to exacting engineering standards. This lock is rated as Safe Pro, a rating awarded to Kensington Security Locks that are tested under stringent test conditions by third party testing agencies for their ability to withstand attacks.
We provide two keys with each standard lock. Each key is stamped with a unique code. Register your code online and well be able to send you a replacement key.
Our business is protecting yours
Kensington locks are made with high-carbon steel cables and tested under rigorous real-world conditions to resist lock-picking, corro.
Kensington MicroSaver security cable lock
Security cable lock
Package Content
Security cable
Length
1.8 m
Key lock, T- bar lock
Package Type
Retail
Security cable lock
Package Content
Security cable
Length
1.8 m
Package Type
Retail
Limited warranty - lifetime
Kensington Slim MicroSaver Security Kit Bundle deal on Kensington Slim MicroSaver Security Kit
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£40.45
saving £4.99
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 2J7J 033680
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £11.52
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Security Kit
Brand: Kensington
Price Range Inc VAT: 0 - 50
