BT.com
Wishlist
Kensington Proximo™ Starter Kit
Delivery
Standard Due date unavailable
Make your iPhone®, keys and valuables unforgettable
Every 3.5 seconds, a mobile phone is lost or stolen. When you consider the threat to your sensitive data, your downtime and the cost of recovering your phone, you'll understand exactly why Kensington Computer Products Group developed Proximo. Proximo is an app-enabled proximity monitoring system that lets you know where your iPhone, keys and valuables are at all times. With Proximo, you'll never have to worry again about leaving your iPhone and valuables behind. That's because Proximo helps you keep, track and get back your iPhone and valuables.
  • Wireless technology: Bluetooth® 4.0 / Bluetooth Smart
  • Replaceable Battery: Model: CR2032 Lithium Coin Battery
  • iOS Compatibility: iPhone 4S: iOS 5 / iOS 6 or later; iPhone 5: iOS 6 or later
  • Inside: Proximo Fob & Tag, 2 Coin Batteries, 1 Key-Ring, 1 Miniature Screw Driver
  • Last Seen provides you with pin-drop on map to help you recover your items
  • Up to 6-month battery life on FOB & TAG for low maintenance
  • Personalize your FOB and TAG with customizable alarm tones, images and names
  • Robust and ultra-slim 8mm FOB and TAG design
  • Monitor the battery life of all your TAGs and FOBs from your iPhone
  • Compatible with iPhone 5 and iPhone 4S
How it works:
Keep: Simply download Proximo App from App Store onto your iPhone and attach the fob to your keys. Now, the moment you move a set distance away from your iPhone, Proximo's Key Fob will alert you with a customizable alarm, making it all but impossible to lose your iPhone.
Track: Tired of misplacing your keys? With Proximo, you'll use your iPhone to track your keys, so you'll never lose them again. And once you have the Proximo Starter Kit, you can buy additional tags to keep track of up to 4 important items, like your camera, laptop bag, car, and much more. Each tag can be personalized with its own unique sound and photo.
Get Back: Can't find an important item? The Proximo App will automatically drop a pin on a Google map to show you where you had it last. As you move within range of a misplaced item, the proximity meter on your iPhone will work like a Geiger counter to help you hone in on its location, while the item's tag emits its unique tone. No more stressing over losing important items or wasting time searching for them. Let Proximo help you recover your lost iPhone, keys and more.
Proximo - see it working
Kensington Proximo Starter Kit - proximity monitoring system
Proximity monitoring system
Package Content
Wireless security fob, wireless security tag
Europe
Apple iPhone 4S, 5
Package Content
Europe
Apple iPhone 4S, 5
Scroll to top
