BT.com
Wishlist
Kensington Brushed Aluminium 2.1A 5200mAh USB Mobile Charger
Delivery
Standard Due date unavailable
When youre on the road and need to power your device, the Kensington 5200 USB Mobile Charger is the perfect answer to boost a drained battery. The mobile charger features a 5200 mAh battery that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminum cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
Kensington Power Bank 5200 Mobile Charger - power bank x 18650 Li-Ion
Power bank
5.5 cm x 9.1 cm x 2.2 cm
152.4 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
18650 - Lithium Ion 5200 mAh
Power Device Details
- 4 pin USB Type A - 5 V - 2.1 A
Cables
Micro-USB charge cable
Power bank
5.5 cm
9.1 cm
2.2 cm
152.4 g
Enclosure Colour
Silver
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.1 A
PowerWhiz technology
Lithium Ion
Voltage Provided
5 V
5200 mAh
Circuit protection, battery level indicator
Scroll to top
