BT.com
Wishlist
Kensington Brushed Aluminium 2.1A 10400mAh USB Mobile Charger
Delivery
Standard Due date unavailable
When youre on the road and need to power your device, the Kensington 10400 Mobile USB Charger is the perfect answer to boost a drained battery. The mobile charger features a 10,400 mAh battery and a 2.1 AMP output that has enough reserve power to fully charge an iPhone 6 Plus or a Galaxy S5 two times. The high-grade LG battery cell and high-quality components ensure your device charges safely and efficiently. With PowerWhiz Technology, the charger automatically detects your device and provides the fastest charge possible. A stylish aluminium cover finish creates a professional look and the 4-LED display lets you know how much power is left in the charger. The power bank can be used with a wide variety of devices including all Apple products, most Android smartphones and tablets, and many other USB-charged devices.
Kensington Power Bank 10400 Mobile Charger - power bank - 18650 - Li-Ion
Power bank
7.7 cm x 9.1 cm x 2.2 cm
255 g
Output Connector Type
USB
5 V
Voltage Provided
5 V
18650 - Lithium Ion 10400 mAh
Power bank
7.7 cm
9.1 cm
2.2 cm
255 g
Enclosure Colour
Silver
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 1: 4 pin USB Type A
Max Electric Current
2.1 A
Output Details
5 pin Micro-USB Type B - 5 V - 1 A , 4 pin USB Type A - 5 V - 2.1 A
PowerWhiz technology
Lithium Ion
Voltage Provided
5 V
10400 mAh
LED power meter, circuit protection
USB charge cable
Scroll to top
