BT.com
Wishlist
Kaiser Baas X100 Sports Camera 1080p
Delivery
Standard Due date unavailable
With a recording resolution of 1080p HD at 30 frames per second and a wide-angle field of view at 150 degrees, the X100 Action Camera consistently produces clear, focused footage that is fantastic to view. The X100 Action Camera with Wi-Fi lets you view, download and share your footage with ease and the Wrist Remote allows for control of recording without having to play around with the setup of the X100.
The X100 Action Camera with W-iFi lets you view, download and share your footage with ease and the wrist remote allows for control of recording without having to play around with the setup of the X100.
What's in the box
  • Kaiser Baas X100
  • USB cable, mounting screw, underwater housing, curved adhesive mount, 2 adhesive pads, flat adhesive mount, remote control wristband, quick release mount
Kaiser Baas X100 - action camera
Action camera - 1080p - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wi-Fi
Sensor Resolution
5.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens 2.65 mm f/2.5
Focus Adjustment
Focus free
Min Focus Distance
50 cm
Display
LCD display - 2"
Supported Battery
1 x Li-ion rechargeable battery - 1060 mAh (included)
HDMI, USB 2.0
5.4 cm x 3.7 cm x 5.1 cm
77 g
Camcorder Sensor Resolution
5.0 MP
Camcorder Interpolated Photo Resolution
12.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.5"
Frame Rate (Max Resolution)
30 fps
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 1080
HDMI, USB 2.0, Wireless LAN
Exposure & White Balance
Light Sensitivity
ISO auto (100-200)
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, daylight, fluorescent light (warm white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/30 sec
Lens System
Wide-angle lens 2.65 f/2.5
Focus Adjustment
Focus free
Min Focus Distance
50 cm
Max View Angle
150 degree(s)
Additional Features
Self-Timer Delay
Additional Features
Auto power save, date/time stamp, Time-Lapse recording, Loop recording
Action Camera Features
Camera Type
Mountable
Display
2" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , HDMI output
Protection
Waterproof
Underwater Use
Underwater Depth
Up to 30 m
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Video recording - 1.33 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Max Supported Size
32 GB
Video Capture
1920 x 1080 p - 30 fps , 1280 x 720 p - 60 fps , 1280 x 720 p - 30 fps
5.4 cm
3.7 cm
5.1 cm
77 g
Scroll to top
