BT.com
Wishlist
Kaiser Baas X 80 Water proof HD Action Camera 1080p 2" LCD Screen
Delivery
Standard 3-5 working days
Capture stunning footage with the X80 everywhere you go. Your adventures and experiences are worth capturing. From holidays with family and friends to bike rides, swimming lessons and trips to the beach.
Waterproof up to 30m With the supplied X80 accessory kit, you ready to capture the action. On the ground, in the air or underwater to a depth of 30m.
Easy to use
With a simple two button operation, the X80 is the perfect camera to get you recording those moments at quick notice, so you don’t miss a thing. With the waterproof housing and a selection of mounts already included, you’re ready to go.
Full HD Video Capture motion video at full HD resolution: 1080p @ 30fps. Play the video directly from the X80 to your TV via the built in HDMI port. The X80 offers 5MP photos using its ultra wide 120° lens.
Snapshots with One Click Don’t miss out on crucial moments! The simple two button operation means you can toggle between video and photo modes quickly and easily.Simple two button operation means you can toggle between video and photo modes quickly and easily so you don’t miss crucial moments.
Built-in display The X80 comes fitted with a digital 2-inch screen so you can perfectly frame your shots and videos. Built with clarity in mind, the X80 won’t ever leave you stuck with over-saturated footage or stills.
Take it outdoors Mount your X-Series Action Camera or GoPro to your bike, or your car, even on your chest or helmet
Kaiser Baas X80 - action camera
Action camera - 1080p - widescreen
Action Camera Type
Mountable
Memory Card Slot
microSD card
Sensor Resolution
5.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens 3.1 mm f/2.8
Focus Adjustment
Focus free
Min Focus Distance
50 cm
Display
LCD display - 2"
Supported Battery
1 x Li-ion rechargeable battery - 1600 mAh (included)
HDMI, USB 2.0
5.4 cm x 2.6 cm x 5.1 cm
90 g
Camcorder Sensor Resolution
5.0 MP
Camcorder Interpolated Photo Resolution
12.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.5"
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 1080
HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO auto (100-200)
White Balance
Automatic, presets
Max Shutter Speed
1/2000 sec
Min Shutter Speed
1/30 sec
Lens System
Wide-angle lens 3.1 f/2.8
Focus Adjustment
Focus free
Min Focus Distance
50 cm
Max View Angle
120 degree(s)
Additional Features
Additional Features
Date/time stamp, Time-Lapse recording, Loop recording
Action Camera Features
Camera Type
Mountable
Display
2" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , HDMI output
USB cable, mounting screw, underwater housing, curved adhesive mount, 2 adhesive pads
Protection
Waterproof
Underwater Use
Underwater Depth
Up to 30 m
Battery Type
Lithium Ion - manufacturer-specific
Details
Battery Life Details
Video recording - 1.33 hours
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Max Supported Size
32 GB
Video Capture
1920 x 1080 p - 30 fps , 1280 x 720 p - 60 fps , 640 x 480 - 120 fps
5.4 cm
2.6 cm
5.1 cm
90 g
Scroll to top
