BT.com
Wishlist
Jawbone UP3 Sand Twist
£106.51
£106.51
Add to wishlist
Delivery
Standard Due date unavailable
The world's most advanced tracker
Everyone has had a life-changing experience sometime. This is one of those times. UP3™ is simply the most advanced tracker you can buy. Its classic, durable design will stand the test of time. Multi-sensor technology adds breadth and accuracy to Smart Coach. Everything about UP3 says that the bar has been set higher. Wear one and go further.
Jawbone UP3 activity tracker - sand twist
Activity tracker
Bluetooth
Supported Host Device OS
iOS, Android
Tracking Data
Distance, calories burned, activity, sleep activity, heart rate, steps taken, food & drink logging
Heart rate sensor, LED indicator(s)
Sand twist
Case Material
Rubber, anodised aluminium
12.2 mm x 9.3 mm
Length
220 mm
29 g
1 year warranty
Activity tracker
Integrated Components
Heart rate sensor
Android 4.3 (Jelly Bean) or later
Tracking Data
Sand twist
LED indicator(s), thermometre, three-axis accelerometer, heart rate, galvanic skin response sensor
Wireless Interface
Bluetooth 4.0
Lithium polymer
38 mAh
Standby Time
168 h
Recharge Time
100 min
12.2 mm
9.3 mm
Length
220 mm
29 g
Vibrating Alert
Body Material
Protection
Splashproof
Magnetic charging cable
Warranty
1 year warranty
Scroll to top
