BT.com
Wishlist
Jabra Stone 3 Single In Ear Mono Bluetooth Headset - White
Delivery
Standard Due date unavailable
When you need a headset that sounds great, feels great and looks great - look no further. Jabra Stone3 is simply a real standout among high-end headsets. Because great design goes a long way, the headset's light and curvy design will fit comfortably to the shape of your ear at all times. And when you're on-the-go, put the headset back in its sleek pocket-sized charging stone and it's ready to be taken with you anywhere.
Jabra STONE3 - headset
Headset - Bluetooth - wireless - NFC
Recommended Use
Portable electronics
White
Headphones Form Factor
Over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0 EDR
Sound Output Mode
Mono
Impedance
16 Ohm
Active Noise Canceling
Microphone
Built-in
Controls
Answer/end
1 year warranty
Headset - Bluetooth - NFC
5.07 cm
2.47 cm
5.8 cm
7 g
White
Recommended Use
Max Operating Distance
10 m
Headphones
Over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Available Microphone
Bluetooth Version
Bluetooth 3.0 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Phonebook Access Profile (PBAP)
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Impedance
16 Ohm
Diaphragm
10 mm
Microphone
Audio Input Details
Omni-directional
Remote Control
Controls
Answer/end
Wireless Link
Transmission Range
10 m
Connector Type
USB (5 pin Micro-USB Type B)
USB cable
3 gel ear tips
GOST, IC, FCC, RoHS, KCC, TELEC, REACH, NCC, iDA
Headset charging stand + power adapter - external
AC 120/230 V (50 - 60 Hz)
Headset battery rechargeable
Run Time (Up To)
2 hour(s)
Standby Time
360 hours
Limited warranty - 1 year
Scroll to top
