BT.com
Wishlist
Jabra SPEAK410 USB Speaker MS
£70.08
31 in stock
£70.08
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Jabra SPEAK 410 is a speakerphone designed for office professionals with everyday need for audio conferencing. Its compact design and travel case make it easy to carry around, and the integrated cable management ensures quick set-up. It's the perfect solution for spontaneous conferencing and collaboration.
Jabra SPEAK 410 MS is optimized for seamless integration with Microsoft Lync. Simply connect Jabra SPEAK 410 MS to your computer and you are ready to make your first call. The unique and intuitive on-device call controls allow you to adjust the volume, mute and even answer or end a call. The external ringer ensures that you never miss a call.
* Optimized for Microsoft® Lync™
* Intuitive on-device call controls
* Integrated cable management and travel case
* Headset port for private calls
Jabra SPEAK 410 MS - USB VoIP desktop hands-free
USB VoIP desktop hands-free - wired
Wired
Sound Output Mode
Mono
Microphone
Built-in
Microphone Operation Mode
Mono
Controls
Volume, answer/end
2 years warranty
Headphones
Wired
Sound Output Mode
Mono
Microphone
Mono
Audio Input Details
Omni-directional
Remote Control
Controls
Volume, answer/end
Connector Type
USB (4 PIN USB Type A) , Headset (mini-phone 3.5 mm 4-pole)
USB cable
Resources
The following resources are available for the Jabra SPEAK410 USB Speaker MS
Scroll to top
