BT.com
Wishlist
Jabra Secure Mount For Speak 410/510
Jabra Secure Mount For Speak...
£11.74
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
£11.74
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Once your Jabra SPEAK has become a natural part of your way of communicating, it is very unfortunate if it is not available when you need it. The solution is to mount a Jabra SPEAK secure mount on the table.
Your Jabra SPEAK is easily mounted in the secure mount so subsequently it is difficult to remove it without the proper screwdriver . Of course you can always easily remove your Jabra SPEAK and take it with you when you need ultimate mobility.
Scroll to top
