BT.com
Wishlist
Jabra PRO 9470, Mono, Triple Connectivity Wireless Headset with Touchscreen
Jabra PRO 9470, Mono, Triple...
£256.38
£256.38
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Thursday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Today's business cards often feature different numbers for desk, mobile and softphone. The result? You find yourself grabbing your mobile just as the caller gives up and tries the desk phone instead! Designed with busy managers and specialists in mind, Jabra PRO 9470 can save you a lot of hassle. Thanks to Multiuse technology, all your phone calls come to the same headset. Just tap the talk button and start talking.The three devices - desk, mobile and softphone - are united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. Equipped with a SmartSetup wizard, the touch screen helps you connect phones and choose preferences to get started. Once you're up and running, it's colorful icons and intuitive menu system make call-handling a breeze.Several state-of-the-art sound technologies enable the Jabra PRO 9470 to deliver unrivaled call clarity and safety. A dual microphone Noise Blackout system with advanced Digital Signal Processing practically eliminates all background noise, so your voice can always be heard clearly. Wideband quality ensures that the sound you hear is crystal clear, while SafeTone technology protects your hearing.
Jabra PRO 9470 - headset
Headset - wireless - DECT
Recommended Use
Portable electronics, phone, computer
Hong Kong, Singapore, United Kingdom
Headphones Form Factor
Convertible
Wireless - DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 6800 Hz
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, tone, answer/end
2 years warranty
Headset - DECT
28 g
Recommended Use
Headphones
Convertible
Wireless - DECT
Available Microphone
Sound Output Mode
Mono
Active Noise Cancelling Technology
Noise Blackout
Frequency Response
150 - 6800 Hz
Microphone
Boom
Remote Control
Controls
Wireless Link
Transmission Range
150 m
USB cable , Phone cable
Neck strap, headband, power adapter, base station, headset charging cradle, earhook
EN 60950, UL 60950, FCC, IEC 60950-1
Headset battery rechargeable - Lithium Ion
Included Qty
1
315 mAh
Run Time (Up To)
8 hour(s)
Standby Time
46 hours
Accessories
Jabra PRO 9400 Neckband
Quicklinx: 7C2V | In Stock
£18.03
Jabra PRO 9400 Headband
Quicklinx: 7C2X | In Stock
£15.18
Jabra PRO 9400 Earhook
Quicklinx: 7C2Y | In Stock
£15.18
Jabra PRO 9400 Series Ear Pads
Quicklinx: 7C2Z | In Stock
£7.69
Resources
The following resources are available for the Jabra PRO 9470, Mono, Triple Connectivity Wireless Headset with Touchscreen
Scroll to top
