BT.com
Wishlist
Jabra PRO 9460, NC, Mono, Dual Connectivity Wireless Headset with Touchscreen
Jabra PRO 9460, NC, Mono, Dual...
£236.01
25 in stock
£236.01
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
Jabra PRO 9460 - headset
Headset - wireless - DECT
Recommended Use
PC multimedia, corded phone, mobile phone
Hong Kong, Singapore, United Kingdom
Headphones Type
Headphone - monaural
Headphones Form Factor
Convertible
Wireless - DECT
Sound Output Mode
Mono
Frequency Response
150 - 6800 Hz
Microphone
Boom
2 years warranty
Headset - DECT
31 g
Recommended Use
Noise cancelling circuit, mute button, answer/end button, volume control, touch sensor operation, built-in DSP, PeakStop Technology, Jabra SafeTone technology
Headphones
Headphones Type
Convertible
Wireless - DECT
Sound Output Mode
Mono
Frequency Response
150 - 6800 Hz
Microphone
Boom
Wireless Link
Transmission Range
150 m
1 x USB cable - external , 1 x phone cable - external
Neck strap, headband, power adapter, base station, headset charging cradle, earhook
EN 60950, UL 60950, IEC 60950-1
Headset battery - rechargeable
Included Qty
1
Run Time (Up To)
10 hour(s)
Standby Time
46 hours
2 years warranty
Service & Support Details
Accessories
Jabra PRO 9400 Headband
Quicklinx: 7C2X | In Stock
£15.18
Jabra PRO 9400 Earhook
Quicklinx: 7C2Y | In Stock
£15.18
Resources
The following resources are available for the Jabra PRO 9460, NC, Mono, Dual Connectivity Wireless Headset with Touchscreen
Scroll to top
