BT.com
Wishlist
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Jabra Motion UC + Bluetooth Headset With Travel & Charger Kit - Hard Case
Delivery
Standard Due date unavailable
  • Description
  • Specifications
  • Bundle deals
  • Accessories
  • Resources
  • Customer reviews
  • Buy used stock
  • Find similar
Jabra Motion is second to none in terms of innovative features and future proof technology.
Designed for maximum convenience and providing superior wearing comfort, it helps simplify your busy lifestyle. It is the only headset you'll ever need.
Built-in motion sensors reacts to your movements and different sound environments, enabling intuitive call control, unsurpassed battery performance and superior audio quality.
Intuitive call control
Jabra Motion automatically answers when picked up and adjusts speaker volume to your movement and surrounding noise- all because of the built-in motion sensors. With the voice control you can pick up just by saying "answer" and the foldable boom arm also makes it easy to answer and end calls.
Custom fit for optimal comfort
As the only Bluetooth headset on the market, you can adjust the height of the speaker house and with 3 sizes of ear gels, the headset can be custom fit for all day comfort.
Superior audio performance
As you would expect, Jabra Motion ensures your every word counts thanks to its outstanding audio capabilities- in any environment. HD voice, Noise Blackout 3.0 and Wind Noise Reduction technology are all included as standard.
Tap to connect with NFC
Near Field Communication technology (NFC) makes it easy to instantly connect and interact with phones, tablets, and interactive tags. Just tap the phone and the headset together and they are connected. Watch the video to see how easy it is to connect using NFC.
Best in class wireless freedom
There is no need for bringing the phone around the office. With the Jabra Motion UC, Bluetooth Class 1 gives you wireless freedom with a range of up to 100m/300ft from your PC, tablet or smartphone. That is 10 times the range of similar headsets on the market.
Travel & Charge Kit
The Travel & Charge kit gives you maximum convenience and makes the Jabra Motion UC the perfect choice for both business and private life.
Key Features
* Headset with superior comfort
* Large intuitive touch volume control area
* Voice Commands/Announcements
* Flip boom-arm
* Noise Blackout microphone technology
* NFC (Near Field Communication)
* Motion Sensors
* Up to 100m range (BT Class 1) when used with Jabra LINK 360 Nano dongle
* Up to 7 hours talk-time
* Wideband (HD Voice) and A2DP
* Power Save mode to maximize talk time
* Jabra Connect App for Smartphones/ Tablets
* Jabra PC Call Manager call control via your
* PC screen with mouse or keyboard
* Jabra LINK 360 Nano USB adapter included
* Online indicator on earpiece shows others you are on a call
* Charges whilst docked on the travel case.
* Folds away neatly within the box whilst not in use
Scroll to top
