BT.com
Wishlist
Jabra GN2000 Mono Noise Cancelling Headset
Delivery
Standard Due date unavailable
The Jabra GN2000 Series lets you hear every detail, the first time. For PC-based IP telephony, the Jabra GN2000 IP and Jabra GN2000 USB supports the full IP network bandwidth for applications such as speech recognition, voice-over-IP calling and computer-based training. For traditionel telephony, the Jabra GN2000 Series is the ideal headset for busy and noisy environments, utilising the full frequency of the telephone network to ensure exceptional sound quality on every call.
From its sturdy rubber-plastic composite to reinforced strain relief and impact resistant headbands, every detail of the Jabra GN2000 Series has been designed with durability in mind - making it perfect for even the most demanding contact centres.
  • Robust design for day-after-day durability
  • Optimized for contact center use
  • Noise canceling microphone for the noisy environment
  • Wideband sound
Jabra GN2000 MONO NC WB - headset
Headset - wired
Recommended Use
Conference
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 6800 Hz
Impedance
200 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
2 years warranty
Headset
52 g
Recommended Use
Conference
Headphones
Supraaural
Wired
Available Microphone
Sound Output Mode
Mono
Frequency Response
150 - 6800 Hz
Impedance
200 Ohm
Microphone
Boom
Mono
Wired
Sensitivity
-34 dB
Resources
The following resources are available for the Jabra GN2000 Mono Noise Cancelling Headset
Scroll to top
