BT.com
Wishlist
Jabra Freeway Bluetooth Speakerphone
Delivery
Standard Due date unavailable
The Jabra FREEWAY in-car speakerphone makes hands-free calls sound better than ever - and makes controlling them effortless. It is the first in-car speaker-phone to have a 3-speaker stereo system and virtual surround sound, which makes the audio crisper, clearer and more vibrant than ever before. And with its dual-microphone technology, you can say goodbye to unwanted background noise.
The Jabra FREEWAY is extraordinarily easy to operate. That's because with the Jabra FREEWAY, voices are in control. To start with, voice guidance will talk you through setup and pairing. After that, it will announce the name of the incoming callers, ask if you want to accept their calls and will tell you battery level and connection status. You then simply use your own voice to make, answer, end, redial or reject calls - while keeping both hands safely on the wheel. And there is no need to press buttons to turn the Jabra FREEWAY on or off. It automatically turns on when you get into your car and off when you get out.
Jabra FREEWAY - speaker phone
Speaker phone - wireless - Bluetooth
Recommended Use
Portable electronics
Additional Functions
FM transmitter
Wireless - Bluetooth
Bluetooth Version
Bluetooth 2.1 EDR
Sound Output Mode
Surround Sound
Sound Effects
Virtual surround sound
Audio Specifications
Frequency Response 300 - 18000 Hz
Active Noise Canceling
Microphones Included
2
Controls
Mute, volume, on/off, answer/end
1 year warranty
Speaker phone - Bluetooth
FM transmitter
12 cm
9.9 cm
1.9 cm
115 g
Recommended Use
Headphones
Bluetooth Version
Bluetooth 2.1 EDR
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP)
Sound Output Mode
Surround Sound
Sound Effects
Active Noise Cancelling Technology
Noise Blackout Extreme
Frequency Response
300 - 18000 Hz
Microphone
2
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
10 m
USB charge cable
GOST, IC, FCC
Power adapter - car - external
DC 12 - 24 V
Voltage Provided
5 V
Speaker phone battery rechargeable
Run Time (Up To)
14 hour(s)
Standby Time
960 hours
Limited warranty - 1 year
Resources
The following resources are available for the Jabra Freeway Bluetooth Speakerphone
Scroll to top
