BT.com
Wishlist
Jabra EHS Solution
Jabra EHS Solution
£29.55
Jabra EHS Solution
Jabra EHS Solution
More than 50 in stock
£29.55
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Polycom SoundPoint IP phones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
Jabra EHS Adapter - headset adapter - 92.5 cm
Cable
Headset adapter
Length
92.5 cm
Jabra GN9120 Duo, GN9120 Midi, GN9350; Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Cable Type
Headset adapter
Length
92.5 cm
C-Tick, NOM, IC, FCC
Jabra GN9120 Duo, GN9120 Midi, GN9350 , Polycom SoundPoint IP 320, IP 330, IP 430, IP 550, IP 560, IP 650
Scroll to top
