BT.com
Wishlist
Jabra Boost - Black (inc dual charger)
Jabra Boost - Black (inc dual...
£27.16
£27.16
Add to wishlist
Delivery
Standard Due date unavailable
You never need to worry about running out of battery. The Jabra Boost is small and slim, it gives you all the power you need. With long hours of talk time, and long standby time, with the Power Nap feature, this allows you to take calls all day and takes the worry away. No more running out of battery, when you are on-the-go.
Jabra Boost is easy to use. Voice guidance prompts will guide you through the pairing process, tell you when you are low on battery, and even when you connect or disconnect your phone. The intuitive dedicated on/off slider and volume control button makes the headset even easier to handle, so you will never miss a call.
Just leave your smartphone in your pocket - with Jabra Boost, Siri and Google Now are always available at your fingertips. Just tap the dedicated headset button to activate and engage with Siri or Google Now from your smartphone.
Jabra Boost - headset
Headset - wireless - Bluetooth
Recommended Use
Portable electronics
Headphones Form Factor
In-ear - over-the-ear mount
Wireless - Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 4.0 EDR
Sound Output Mode
Mono
Microphone
Built-in
Controls
Volume, on/off, answer/end
1 year warranty
Headset - Bluetooth
1.45 cm
4.93 cm
0.95 cm
8.5 g
Recommended Use
Headphones
Dynamic
Available Microphone
Bluetooth Version
Bluetooth 4.0 EDR
Bluetooth Profiles
Hands Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP)
Sound Output Mode
Mono
Diaphragm
11 mm
Microphone
Frequency Response
200 - 6800 Hz
Audio Input Details
Omni-directional
Remote Control
Controls
Wireless Link
Transmission Range
30 m
Connector Type
USB (5 pin Micro-USB Type B (power only))
USB charge cable
Ear tips kit, 2 earhooks
GOST, IC, FCC, RoHS, REACH
Power adapter - car - external
Headset battery rechargeable
Run Time (Up To)
9 hour(s)
Standby Time
216 hours
Recharge Time
2 hour(s)
Limited warranty - 1 year
Scroll to top
