BT.com
Wishlist
Jabra BIZ 1500 USB Duo Wideband Headset
Jabra BIZ 1500 USB Duo Wideband...
£61.94
£61.94
Add to wishlist
Delivery
Standard Due date unavailable
Jabra BIZ 1500 Duo USB headset is a professional grade entry level USB Computer headsets with excellent value for call centers. It comes complete with a USB plug for instant plug-and-play computer connection, letting you benefit from its clear sound and low cost of ownership. Equipped with a noise-cancelling microphone and HD quality sound. Its light weight headband provide all day comfort for your call-intensive office
Great sound
  • Noise-cancelling Air Shock microphone reduces background noise and sharp breathing sounds – ideal for crowded open offices.
  • HD Voice makes your conversations sound vibrant and lifelike.
All-day comfort
  • Made to be worn all day, with ergonomically designed frame, padded headband and super soft foam ear cushions that divert heat away from your ears.
  • Headband and microphone boom can be adjusted to suit your preference.
Tough Design
  • Built to survive in a high-performing contact centre, with a boom-arm that can be rotated 270 degrees without the risk of breaking.
Jabra BIZ 1500 Duo - headset
Headset - wired - USB
Recommended Use
Phone
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 4500 Hz - Sensitivity 115.5 dB/mW
Impedance
150 Ohm
Max Input Power
30 mW
Microphone
Boom
2 years warranty
Headset - USB
13.1 cm
5.7 cm
16.5 cm
146 g
Earpad Material
Foam
Recommended Use
Phone
Headphones
Supraaural
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 4500 Hz
Max Input Power
30 mW
Sensitivity
115.5 dB/mW
Impedance
150 Ohm
Microphone
Boom
Sensitivity
-32 dBV/Pascal
Frequency Response
1000 - 5000 Hz
Audio Input Details
Uni-directional - 1000 - 5000 Hz
Connector Type
USB (4 PIN USB Type A)
Cable
Cable Length
95 cm
Headset cable - 95 cm
Scroll to top
