BT.com
Wishlist
istorage diskGenie 256-bit SSD 1TB USB 2.0
istorage diskGenie 256-bit SSD 1TB...
£647.55
£647.55
Add to wishlist
Delivery
Standard 1-3 working days
The iStorage diskG is the secure, compact and affordable USB 2.0 portable hard drive, employing PIN code access with 128-bit or 256-bit AES hardware encryption. The iStorage diskG utilizes military grade AES 128-bit or 256-bit hardware encryption, which encrypts ALL data stored on the drive in real time, making it as fast and in many cases faster than any non-encrypted USB 2.0 hard drive.
iStorage diskG - solid state drive - 1 TB - USB 2.0
Solid state drive - external (portable)
1 TB
Hardware Encryption
USB 2.0
Data Transfer Rate
480 Mbps
Shock resistant, built-in keypad, password authentication, hardware encryption, administrator password, Brute-Force Password Attack Protection, 256-bit AES
Power Source
USB bus
84.5 mm x 120 mm x 19 mm
176 g
2 years warranty
1 TB
Hardware Encryption
USB 2.0
84.5 mm
120 mm
19 mm
176 g
Performance
Interface Transfer Rate
480 Mbps
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2 or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - Pentium RAM 32 MB , MacOS X 10.2 or later - PowerPC G3
Carrying case
1 x USB cable - integrated
Plug and Play, FCC, RoHS, WEEE, CESG Claims Tested Mark (CCTM)
Limited warranty - parts and labour - 2 years
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Scroll to top
