BT.com
Wishlist
istorage diskAshur2 256-bit 1TB - Red
istorage diskAshur2 256-bit 1TB -...
£222.51
Hurry, only 1 left in stock!
£222.51
Add to wishlist
Delivery
Standard 1-3 working days
Looking for an effortless way to secure your data while taking advantage of the fastest USB 3.0 speeds? Look no further than the diskAshur, the fast of iStorage's secure drive line. With the same easy-to-use keypad design and software free setup, the diskAshur enables you to access the drive with your own unique pin but now at data transfer speeds of up to 5 Gbps.
iStorage diskAshur 2 - hard drive - 1 TB - USB 3.1 Gen1
Hard drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.1 Gen1
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
5400 rpm
Security lock slot (cable lock sold separately), water resistant, dust-proof, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, wear-resistant, tamper-resistant, PIN code authentication, EDGE (Enhanced Dual Generating Encryption), EAL4+, 256-bit AES-XTS
Power Source
USB bus
Enclosure Colour
Fiery red
12.4 cm x 8.4 cm x 1.9 cm
216 g
2 years warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.1 Gen1
Buffer Size
8 MB
12.4 cm
8.4 cm
1.9 cm
216 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.1 Gen1 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows
Carrying case
1 x USB 3.0 cable - integrated
FCC, RoHS, WEEE, FIPS 197
Enclosure Colour
Fiery red
Scroll to top
