BT.com
Wishlist
istorage diskAshur USB 3.0 256 bit 1TB Portable SSD
istorage diskAshur USB 3.0 256 bit...
£704.97
£704.97
Add to wishlist
Delivery
Standard Due date unavailable
Looking for an effortless way to secure your data while taking advantage of the fastest USB 3.0 speeds? Look no further than the diskAshur, the fast of iStorage's secure drive line. With the same easy-to-use keypad design and software free setup, the diskAshur enables you to access the drive with your own unique pin but now at data transfer speeds of up to 5 Gbps.
iStorage diskAshur - solid state drive - 1 TB - USB 3.0
Solid state drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, built-in keypad, password authentication, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, Wear Resistant Keypad, 256-bit AES
Power Source
USB bus
84.5 mm x 120 mm x 19 mm
176 g
2 years warranty
1 TB
USB 3.0
84.5 mm
120 mm
19 mm
176 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2 or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - Pentium RAM 32 MB , MacOS X 10.2 or later - PowerPC G3
Carrying pouch
1 x USB 3.0 cable - integrated , 1 x power cable - external
Plug and Play, FCC, RoHS, WEEE, FIPS 197, CESG Claims Tested Mark (CCTM)
Limited warranty - parts and labour - 2 years
70 °C
0 - 95%
Shock Tolerance
1500 g @ 0.5ms
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Other bundles
£704.97
Save on Intel Optane 16GB with HDD
Save £5.00
£744.95
Scroll to top
