BT.com
Wishlist
istorage diskAshur Pro FIPS USB 3.0 256 bit 512GB Portable SSD
istorage diskAshur Pro FIPS USB 3.0...
£688.18
£688.18
Add to wishlist
Delivery
Standard Due date unavailable
Looking for the highest level of security for your data while utilizing the fastest USB 3.0 speeds?
Look no further than the iStorage diskAshur Pro, certified and tested to NIST FIPS 140-2 Level 2 requirements. Sporting an easy-to-use keypad design that is impervious to dust and grit, a software free setup and operation, the diskAshur Pro enables you to access the drive simply and easily with your own unique PIN and with a super fast integrated USB 3.0 cable, you can access your data faster than ever before!
iStorage diskAshur Pro - solid state drive - 512 GB - USB 3.0
Solid state drive - external (portable)
512 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, water resistant, built-in keypad, password authentication, dust-proof, Variable Time Circuit (VTC) technology, auto lock, Data at Rest Protection, drive reset, Wear Resistant Keypad, Brute-Force Password Attack Protection, 256-bit AES-XTS
Power Source
USB bus
84.5 mm x 120 mm x 19 mm
190 g
2 years warranty
512 GB
USB 3.0
84.5 mm
120 mm
19 mm
190 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2.x or later, Microsoft Windows Vista / XP / 7 / 8
System Requirements Details
Windows XP/Vista/7/8 - Pentium RAM 32 MB , MacOS X 10.2.x or later - PowerPC G3 RAM 32 MB
Carrying pouch
1 x USB 3.0 cable - integrated , 1 x USB power splitter cable - external
FIPS 140-2 Level 2
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
Other bundles
istorage diskAshur Pro FIPS USB 3.0 256 bit 512GB...
£688.18
Save on Intel Optane 16GB with HDD
Save £5.00
£727.15
Scroll to top
