BT.com
Wishlist
istorage diskAshur Pro FIPS 256bit 2TB USB 3.0
istorage diskAshur Pro FIPS 256bit...
£311.30
£311.30
Add to wishlist
Delivery
Standard Due date unavailable
Looking for the highest level of security for your data while utilizing the fastest USB 3.0 speeds?
Look no further than the iStorage diskAshur Pro, certified and tested to NIST FIPS 140-2 Level 2 requirements. Sporting an easy-to-use keypad design that is impervious to dust and grit, a software free setup and operation, the diskAshur Pro enables you to access the drive simply and easily with your own unique PIN and with a super fast integrated USB 3.0 cable, you can access your data faster than ever before!
iStorage diskAshur Pro - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Spindle Speed
5400 rpm
Shock resistant, water resistant, built-in keypad, password authentication, dust-proof, Variable Time Circuit (VTC) technology, auto lock, Data at Rest Protection, drive reset, Wear Resistant Keypad, Brute-Force Password Attack Protection, 256-bit AES-XTS
Power Source
USB bus
84.5 mm x 120 mm x 19 mm
190 g
2 years warranty
2 TB
USB 3.0
84.5 mm
120 mm
19 mm
190 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2.x or later, Microsoft Windows Vista / XP / 7 / 8
System Requirements Details
Windows XP/Vista/7/8 - Pentium RAM 32 MB , MacOS X 10.2.x or later - PowerPC G3 RAM 32 MB
Carrying pouch
1 x USB 3.0 cable - integrated , 1 x USB power splitter cable - external
FIPS 140-2 Level 2, FCC, RoHS, WEEE, FIPS 197
2 years warranty
Scroll to top
