BT.com
Wishlist
istorage datAshur Pro USB 3.0 256-bit 32GB
istorage datAshur Pro USB 3.0...
£116.71
15 in stock
£116.71
Add to wishlist
Delivery
Standard 1-3 working days
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur Pro - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit SHA, 256-bit AES-XTS
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS
3 years warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 116 MB/s
Write Rate
Up to 43 MB/s
Interface Type
USB 3.0
Auto-locking
Protective sleeve
Limited warranty - 3 years
78 mm
18 mm
8 mm
25 g
Scroll to top
