BT.com
Wishlist
istorage 8GB datAshur Personal 256-bit USB Drive - Dark Blue
istorage 8GB datAshur Personal...
£32.92
£32.92
Add to wishlist
Delivery
Standard Due date unavailable
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur Personal - USB flash drive - 8 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Hardware Encryption
Encryption Algorithm
256-bit AES, 256-bit SHA
Enclosure Colour
Blue
Apple MacOS, Linux, Microsoft Windows, Android
3 years warranty
USB flash drive
Storage Capacity
8 GB
Hardware Encryption
Enclosure Colour
Blue
Compatibility
Non-specific
Read Rate
Up to 27 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
USB On-The-Go compatible, auto-locking, tamper-proof, 10 Key PIN pad, Brute Force Hack Defence Mechanism, DataLock technology
FCC, RoHS, WEEE
Limited warranty - 3 years
17.4 mm
83 mm
8.6 mm
20 g
Scroll to top
