BT.com
Wishlist
istorage 64GB diskAshur USB3 256-bit SSD
istorage 64GB diskAshur USB3...
£168.49
£168.49
Add to wishlist
Delivery
Standard Due date unavailable
Looking for an effortless way to secure your data while taking advantage of lightning fast USB 3.0 speeds? Look no further than the iStorage diskAshur 3.0, the latest addition to the iStorage family of ultra-secure, easy to use and affordable products.
With the same easy-to-use keypad design and software free setup, the iStorage diskAshur 3.0 enables you to access the drive with your own unique pin but now at data transfer speeds of up to 10x faster than USB 2.
iStorage diskAshur - solid state drive - 64 GB - USB 3.0
Solid state drive - external (portable)
64 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, built-in keypad, password authentication, vibration dampening, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, 256-bit AES
Power Source
USB bus
8.5 cm x 12 cm x 1.9 cm
176 g
3 years warranty
64 GB
USB 3.0
8.5 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2.x or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Windows XP/Vista/7 - Pentium RAM 32 MB , MacOS X 10.2 or later - PowerPC G3
Carrying case
1 x USB 3.0 cable - integrated , 1 x power cable - external
Plug and Play, FCC, RoHS, WEEE, FIPS 197, CESG Claims Tested Mark (CCTM)
Limited warranty - parts and labour - 3 years
70 °C
0 - 95%
Shock Tolerance
1500 g @ 0.5ms
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Scroll to top
