BT.com
Wishlist
istorage 640GB diskAshur USB3 128-bit
istorage 640GB diskAshur USB3...
£159.14
£159.14
Add to wishlist
Delivery
Standard Due date unavailable
Looking for an effortless way to secure your data while taking advantage of lightning fast USB 3.0 speeds? Look no further than the iStorage diskAshur 3.0, the latest addition to the iStorage family of ultra-secure, easy to use and affordable products.
With the same easy-to-use keypad design and software free setup, the iStorage diskAshur 3.0 enables you to access the drive with your own unique pin, but now at data transfer speeds of up to 10x faster than USB 2.
iStorage diskAshur - hard drive - 640 GB - USB 3.0
Hard drive - external (portable)
640 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, password authentication, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, 128-bit AES
Power Source
USB bus
8.5 cm x 12 cm x 1.9 cm
176 g
3 years warranty
640 GB
USB 3.0
Buffer Size
8 MB
8.5 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows
Carrying case
1 x USB 3.0 cable - integrated , 1 x USB cable - external
FCC, RoHS, WEEE, FIPS 197
3 years warranty
Limited warranty - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
Scroll to top
