BT.com
Wishlist
istorage 500GB diskGenie 128-bit 5400rpm 8MB USB 2.0 Encrypted HDD
istorage 500GB diskGenie 128-bit...
£137.85
£137.85
Add to wishlist
Delivery
Standard 1-3 working days
The diskGenie from iStorage offers powerful hardware encryption in a compact, portable device with a totally unique difference. With an easy-to-use keypad design and software free setup, the iStorage diskGenie is only accessible using a PIN code similar to using an ATM.
Also featuring AES 256 bit real time hardware encryption, it protects the data on the drive keeping it safe even if the hard drive is removed from its enclosure. Quite simply, the iStorage diskGenie is the ultimate portable hard drive and secure storage system.
With no software to install, easy setup and real-time encryption, the diskGenie is the best way to protect your data, customers and your business.
Its low powered, compact, robust design features a 16-point omni-directional shock mounting system, protecting the drive from drops and knocks. It is perfect for safely transporting data between office and home as well as storing photos, music and video files.
The diskGenie also offers stress free deployment in corporate environments whilst adding secure additional capacity to your system. Allowing the enrollment of up to ten unique user IDs and one administrator, it is an unparalleled business collaboration tool.
iStorage diskGenie - hard drive - 500 GB - USB 2.0
Hard drive - external (portable)
500 GB
Hardware Encryption
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Built-in keypad, password authentication, Hardware Full Disk Encryption (FDE), 128-bit AES
Power Source
USB bus
8.5 cm x 12 cm x 1.9 cm
176 g
3 years warranty
500 GB
Hardware Encryption
USB 2.0
Buffer Size
8 MB
8.5 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
480 Mbps
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2 or later, Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Pentium RAM 32 MB
Carrying case
1 x USB cable - integrated
Plug and Play, FCC, RoHS, WEEE
Limited warranty - parts and labour - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
Other bundles
istorage 500GB diskGenie 128-bit 5400rpm 8MB USB 2.0...
£137.85
Half Price Hard Drive Case with portable hard drives
Save £4.99
£142.84
Scroll to top
