BT.com
Wishlist
istorage 250GB diskGenie 256-bit 5400rpm 8MB USB 2.0 Encrypted HDD
Delivery
Standard Due date unavailable
The iStorage diskG is the secure, compact and affordable USB 2.0 portable hard drive, employing PIN code access with 128-bit or 256-bit AES hardware encryption. The iStorage diskG utilizes military grade AES 128-bit or 256-bit hardware encryption, which encrypts ALL data stored on the drive in real time, making it as fast and in many cases faster than any non-encrypted USB 2.0 hard drive.
iStorage diskG IS-DG-256-250 - hard drive - 250 GB - USB 2.0
Hard drive - external (portable)
250 GB
USB 2.0
Data Transfer Rate
480 Mbps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, administrator password, auto lock, drive reset, Wear Resistant Keypad, 256-bit AES
Power Source
USB bus
8.45 cm x 12 cm x 1.9 cm
176 g
3 years warranty
250 GB
USB 2.0
Buffer Size
8 MB
8.45 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
480 Mbps
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type A
Power Source
USB bus
Linux, Apple MacOS X 10.2 or later, Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium RAM 32 MB , MacOS X 10.2 or later - PowerPC G3
Carrying case
1 x USB cable - integrated
Plug and Play, FCC, RoHS, WEEE, FIPS 197, CESG Claims Tested Mark (CCTM)
3 years warranty
Limited warranty - parts and labour - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
Scroll to top
