BT.com
Wishlist
istorage 16GB datashur 256-bit Military Hardware Encryption USB Flash
istorage 16GB datashur 256-bit...
£83.49
15 in stock
£83.49
Add to wishlist
Delivery
Standard 3-5 working days
The iStorage datAshur is the world's most secure, easy to use and affordable USB flash drive, employing PIN code access with military grade AES 256-bit hardware encryption. The datAshur incorporates a rechargeable battery allowing the user to enter a 7-15 digit PIN onto the on-board keypad before connecting the drive to the USB port.
iStorage datAshur - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, AES-CBC, 256-bit SHA
Apple MacOS, Linux, Microsoft Windows, Symbian OS, Android
3 years warranty
USB flash drive
Storage Capacity
16 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 27 MB/s
Write Rate
Up to 24 MB/s
Interface Type
USB 2.0
Password protection, water resistant, dustproof, USB On-The-Go compatible, auto-locking, customizable PIN, tamper-proof, Brute Force Hack Defence Mechanism, DataLock technology
Protective sleeve
Plug and Play, FCC, RoHS, WEEE, MIL-STD-810F
Limited warranty - 3 years
78 mm
18 mm
10.5 mm
25 g
Scroll to top
