BT.com
Wishlist
istorage 1.5TB diskAshur USB 3.0 128-bit  2.5" Portable Hard Drive
istorage 1.5TB diskAshur USB 3.0...
£252.68
£252.68
Add to wishlist
Delivery
Standard Due date unavailable
Looking for an effortless way to secure your data while taking advantage of the fastest USB 3.0 speeds? Look no further than the diskAshur, the fast of iStorage's secure drive line. With the same easy-to-use keypad design and software free setup, the diskAshur enables you to access the drive with your own unique pin but now at data transfer speeds of up to 5 Gbps.
iStorage diskAshur IS-DG3-128-1500 - hard drive - 1.5 TB - USB 3.0
Hard drive - external (portable)
1.5 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock resistant, built-in keypad, password authentication, rugged, Variable Time Circuit (VTC) technology, Brute Force Self Destruct, auto lock, Data at Rest Protection, drive reset, Wear Resistant Keypad, 128-bit AES-XTS
Power Source
USB bus
8.45 cm x 12 cm x 1.9 cm
176 g
3 years warranty
1.5 TB
USB 3.0
Buffer Size
8 MB
8.45 cm
12 cm
1.9 cm
176 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Seek Time
12 ms (average)
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type A
Power Source
USB bus
Apple MacOS, Linux, Microsoft Windows
Carrying case
1 x USB 3.0 cable - integrated
FCC, RoHS, WEEE, FIPS 197
3 years warranty
Limited warranty - 3 years
Shock Tolerance
300 g @ 2ms (operating) / 1000 g @ 1ms (non-operating)
Scroll to top
