BT.com
Wishlist
Iris Card Corporate 5 Mobile Scanner
Iris Card Corporate 5 Mobile...
£140.05
£140.05
Add to wishlist
Delivery
Standard Due date unavailable
Full mobility is the word! The IRISCard Corporate 5 is a professional and multi-user solution enabling on-the-go users to easily capture information from their business contacts when away from their computer. Ideal for today's mobile lifestyle, it turns contact management into a child's play.
The business card is simply zipped through the cordless, battery-powered scanner, and the scanned image is then either saved in the built-in memory, on an SD card or on a standard USB key. Once back in the office simply insert the SD card into your computer, and the scanned business cards are automatically processed by the Cardiris Corporate software and exported to the Cloud (Salesforce, Google Contacts), Microsoft Dynamics CRM (online and offline), Outlook, ACT!, etc.
IRIS IRISCard Corporate 5 - sheetfed scanner
Sheetfed scanner - portable
Interface Type
USB
Max Supported Document Size
105 x 152.4 mm
Input Type
Optical Resolution
300 dpi
Max Document Size
105 mm x 152.4 mm
Supported Document Type
Business card
Document Feeder Type
Manual
Flash Memory
512 MB
1 x lithium polymer
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7
15.8 cm x 5.4 cm x 4.3 cm
250 g
Interface Type
USB
105 x 152.4 mm
Scanner
Input Type
Optical Resolution
300 dpi
Scanner Features
Powered by USB port
Media Handling
Max Document Size
105 mm x 152.4 mm
Business card
Manual
Flash Memory
512 MB
Supported Flash Memory Cards
Memory Stick PRO, SD Memory Card, xD-Picture Card
USB - Type A , USB - Mini-B
Cleaning brush, calibration card
1 x USB cable
Battery Installed
1 x lithium polymer
Run Time (Up To)
150 pages
Software Included
Evernote Premium (1 year subscription), Cardiris Corporate (5 users license)
System Requirements Details
Windows XP/Vista/7 - Pentium HD 300 MB , MacOS X 10.3.9 or later - PowerPC G3 HD 160 MB
15.8 cm
5.4 cm
4.3 cm
250 g
Scroll to top
