BT.com
Wishlist
ioSafe Rugged Portable Solid State Drive 500GB USB 3.0 FIPS 140-2 with 5 years Data Recovery Service
Delivery
Standard Due date unavailable
The Go-Anywhere ioSafe Rugged Portable SSD hard drive has been designed to withstands the most extreme environments and will keep your data safe - wherever you take it.
The ioSafe Rugged Portable is the safest way to move data. Whether you need to protect data from drops during your commute or protect it from the most extreme environments on the planet, the Go-Anywhere Ultra Rugged Portable hard drive is up to the job.
Data has become increasingly mobile, but with that increased mobility comes increased risk. Delicate portable storage devices can easily be dropped during travel, stolen or exposed to adverse environmental conditions such as extreme temperatures, sand or moisture — all factors which can lead to data loss. The ioSafe Rugged Portable addresses each of these problems. It's tough enough to be used in arctic or desert environments, is shock and crush resistant, has anti-theft features and is backed by ioSafe's unique Data Recovery Service and No-Hassle Warranty. This means that if your ioSafe Rugged Portable stops working for any reason at all during the warranty period, we'll repair or replace the drive and recover the data from your old drive. ioSafe does more to protect your data than any other company.
ioSafe Rugged Portable - solid state drive - 500 GB - USB 3.0
Solid state drive - external (portable)
500 GB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Security lock slot (cable lock sold separately), Full Metal Jacket, Full Suspension Drive, HydroSafe, ChemSafe, EnviroSafe, AltiSafe
Power Source
USB bus
9.9 cm x 14.5 cm x 2.5 cm
1 year warranty
Bundled with
500 GB
USB 3.0
9.9 cm
14.5 cm
2.5 cm
Bundled with
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
Power supply
Software Included
TrueCrypt, Apple Time Machine, Genie Timeline Professional
Apple MacOS 8.6 or later, Microsoft Windows Vista / XP / 7
System Requirements Details
Pentium II - 350 MHz
1 x USB 3.0 cable - external , 1 x USB power splitter cable - external
FIPS 140-2, MIL-STD 810G, AES-256, IP68, ISO/IEC 10118-3:2004
Limited warranty - 1 year
5 - 80% (non-condensing)
Scroll to top
